Troubleshooting
MAX30102 Not Working — No LED Light, FIFO Stuck at 0x00 (ESP32)
userHead Aman.Mishra 2025-11-07 20:42:34 1091 Views0 Replies
Hi everyone,
I’m facing an issue with my MAX30102 PPG Heart Rate & SpO₂ sensor breakout board and would appreciate some help or confirmation if the module might be defective.
Setup:
Microcontroller: ESP32 Dev Board
Connections:
SDA → GPIO 21
SCL → GPIO 22
VIN → 3.3 V
GND → GND
Observations:
I²C scan successfully detects the device at address 0x57, so communication works fine.
Register read/write operations succeed — for example:
LED amplitude registers (0x0C, 0x0D) accept 0x7F
ModeConfig (0x09) accepts 0x07
Problem:
No LED activity: Neither Red nor IR LED lights up (verified visually and via phone camera).
FIFO Write Pointer stays at 0x00 — no samples are generated even with max settings.
Soft reset fails: Reset bit remains set, suggesting the internal state machine isn’t resetting properly.
Supply voltage between 3V3 and GND is around 2.9 V, but the I²C interface still responds correctly.
Likely Cause:
It seems the analog/LED driver section of the MAX30102 is non-functional, while the digital I²C interface still works — possibly a DOA (dead-on-arrival) or burnt module.
Request:
Could anyone confirm if this behavior indicates a damaged LED driver or a fake MAX30102 module (common issue with some boards)?
Any known fixes or verification steps before requesting a replacement would be appreciated.
Thanks in advance for your help!
