General HUSKYLENSMind+
using HUSKYLENS 2, micro:bit V2, and Mind+(V1.8.1 RC3.0)
userHead muneya 2025-11-07 15:46:25 993 Views3 Replies
Dear DFRobot customer support team,
How can I program using HUSKYLENS 2, micro:bit V2, and Mind+ (V1.8.1 RC3.0)?
I cannot select HUSKYLENS 2 from the extensions menu.
Thanks!
2025-11-08 17:25:08
I was able to successfully select HUSKEYLENS 2.
Thank you. I appreciate it!
I plan to use a conversion cable to connect it to the REKA:BIT's Grove connector (I2C).
userHeadPic muneya
2025-11-08 16:39:30
1. Start Mind+.
2. Click the Extensions button in the bottom-left corner.
3. In the Board section, choose Micro:bit.
4. Select the User-Ext section (it’s the last tab on the right in the menu bar).
5. In the “Search or enter project URL…” field, type “huskylens” and press Enter.
6. You will see a panel titled HUSKYLENS 2 AI Camera; click it to select.
7. Go back to the main page of Mind+, and you’ll see the Micro:bit blocks along with a new User Expansion block group for HuskyLens.
… et voilà
userHeadPic Marco.Picarella
Marco.Picarella wrote:
Then let me know how you connected Huskeylens 2 to microbit.
In this page https://wiki.dfrobot.com/Tutorial%20for%20HUSKYLENS%202%20and%20micro:bit%20%20Graphical%20Programming%EF%BC%88Mindplus%EF%BC%89 is reported this list
2. Hardware Connection
**Prepare Materials **
● Hardware
○ micro:bit x 1
○ HUSKYLENS 2 x 1
○ USB Data Cable x 2
○ 4-pin Connection cable x 1
But how physically?
My Huskylens (1) has been connected to Maqueen plus 2.1 that has a I2C post
2025-11-08 16:58:10
