General Easy IoT
DFR1221 ESP32-S3 1.85-inch round display + battery
userHead adam M 2025-11-10 17:32:33 955 Views2 Replies
There is a Qi charger on the board ( DFR1221 ESP32-S3 1.85-inch round display development board) - is there any battery inside ?
- or how can I connect a battery to this board ?
2025-11-10 22:58:43
sad that there is no batt inside.  connecting battery outside this case is diturbing the whole idea of the design :(
userHeadPic adam M
2025-11-10 22:19:11
Plug a 3.7 V LiPo into the BAT connector. Place the board on a Qi charger. The charging LED should light up. The board can then run directly off the LiPo when off the charger.
userHeadPic ahsrab.rifat
