HUSKYLENSMind+
HUSKYLENS V2 extension in Mind+
userHead FETOUI.OUSSAMA 2025-11-10 05:51:00 1549 Views2 Replies
I’m having trouble adding the HUSKYLENS V2 extension in Mind+ (version 1.8.1 RC3.0).
When I try to add the extension, it either doesn’t appear in the list or fails to install properly.
Could you please provide me with the correct procedure or the compatible version of the HUSKYLENS V2 extension for Mind+?
Thank you very much for your help.
Best regards,
Country: Tunisia
Software version: Mind+ v1.8.1 RC3.0
Operating system: Windows 11
2026-02-26 18:16:45
Halo
i am new here
userHeadPic Joni.Jorden
2026-02-26 11:24:20
We sincerely apologize for the late response. By now, you may have resolved your issue. However, if you are still experiencing difficulties, you can try the following methods:
Are you using [Online/Offline/Python] mode?Main Control Board: Specify your board model?(e.g., UNIHIKER K10)Type HUSKYLENS to see if it loads correctly.
userHeadPic Nickccq
