Crazy values on Gravity: PPG Heart Rate Monitor Sensor for Arduino
userHead rafael.fernandes de carvalho 2025-11-14 21:53:21 1014 Views2 Replies
Gravity: PPG Heart Rate Monitor Sensor for Arduino (Analog/Digital)
https://www.dfrobot.com/product-1540.html
Should I simply read the analog pin (A0, for example) and print it to the serial monitor? Doing it this way, the readings don't make sense. They fluctuate wildly with very close values, and there's no logical pulse pattern in the values. What could I be doing wrong? Could you send a simple code for testing, and a wiring diagram?
icon heart.rar 502KB Download(0)
2025-11-14 22:46:51
Make sure that you are meticulously following the connection and code given here:
https://wiki.dfrobot.com/Heart_Rate_Sensor_SKU__SEN0203
It says-"Adjust the finger's position until you notice the LED is flashing regularly as your heartbeat, after several seconds, the Serial Monitor will print your heart rate."
Here is another heart rate sensor-based project that you may like.
https://www.theengineeringprojects.com/2018/01/heart-beat-monitor-using-arduino-proteus.html
userHeadPic ahsrab.rifat
2025-11-14 22:42:50
Yes. You are right. https://wiki.dfrobot.com/Heart_Rate_Sensor_SKU__SEN0203
You will notice changes in the graph shown in the serial plotter if you hit a treadmill or take deep breaths.
