KIT0197-DFM8001 Configuration for 3.3V output
Brayden.Barry 2025-11-18 16:39:26 658 Views1 Replies I am evaluating the KIT0197 for a ultra-low power project
I'd like to output 3.3V with a super-capacitor.
Here is configuration I've set
LDO Output voltage Vh = 3.3, Vl = 1.8
VCF[012] = 010 (changed)
H_EN = 1 (unchanged)
L_EN = 1 (changed)
MPP[01] = 00 (unchanged)
PRIM[234] = 000 (unchanged)
SCL_BAT = CAP (unchanged)
DCSC = 1 (unchanged)
PRIM_1 = 0 (changed)
Is this configuration correct?
As VCF[012] = 010 mentions “Dual-cell super-capacitor”, are the provided super-capacitors single- of dual-cell? Otherwise, how to connect a dual-cell super-capacitor?
The schematics refer to the connectors as J1..J19 but neither the Schematic.pdf and Dimensions & Component Layout.pdf mention those references. Could you please provide a document with the connectors numbers?
Thank you and best regards,
I'm fascinated by the DFM8001 configuration! How does adjusting the Slope Run impact performance in different applications? Could this lead to more efficient power management in IoT devices?
Jisoo.Lanu
