A01NYUB Ultrasonic Distance Sensor on pi 5 without Expansion Board
Owen.Warner 2025-11-18 16:43:34 1923 Views4 Replies Hello,
I am trying to run the A01NYUB Ultrasonic Distance Sensor with my pi 5 directly (no Expansion Board).
I use the https://github.com/DFRobot/DFRobot_RaspberryPi_A02YYUW_Drift Boss library.
Unfortunately, I only get “No data!”.
Any suggestions?
2026-04-25 20:08:51
Lucas.Brantley
“ No data! ” with these sensors is very often a communication issue rather than a code problem. On the Pi 5 in particular, the voltage level mismatch is easy to overlook - without proper level shifting or at least protecting the RX line, the UART won’t behave as expected.
Lucas.Brantley 2025-11-19 16:23:37
ahsrab.rifat
The Raspberry Pi 5’s UART pins are 3.3 V only and not 5-V tolerant. You must use a bi-directional logic-level shifter, or at least a voltage divider on the sensor’s TX to Pi RX line.
ahsrab.rifat
