General UNIHIKER
Unihiker K10 WiFi
userHead Roy.Murray 2025-11-19 01:41:59 1655 Views3 Replies
I've tried all the suggestions I can find on the web for connecting the unihiker k10 to my wifi.  Nothing works.  Any suggestions would be helpful.
2025-12-12 07:38:37
Given that I've only received one reply to my original inquiry, I'm guessing that no one knows how to connect a Unihiker K10 to WiFi or that it isn't actually possible to connect a Unihiker K10 to WiFi.  If this is incorrect, I'm hoping that someone can provide a detailed description of how to do this.  I'm also hoping that development is continuing on the K10 because it seems like it has potential to be a useful device, but right now it appears to be half-baked.
userHeadPic Roy.Murray
FR wrote:
Sometimes it is not from K10, etc, but  from Windows Defender or any other anti virus software that you have that for security reasons do not allow Lan to Lan communications.
2026-06-28 11:20:04
2025-11-19 01:48:06
The K10 often only supports 2.4 GHz WiFi. The Xiaozhi firmware specifically does not support 5 GHz. If your router is running both 2.4 GHz and 5 GHz, check that you are connecting to the correct band.
userHeadPic ahsrab.rifat
