Raspberry Pi 5 UPS-DFRobot wrong battery level
Raf.el 2025-11-19 00:00:43 2103 Views2 Replies Hello! I'm using the Raspberry Pi 5 UPS-DFRobot and it works great. However, I can't properly get the battery level. Using the official script shows a completely different battery level than the leds on the board. For example, at this exact moment, all the four leds are on, but the script shows a battery of just 18%. The batteries are brand-new.
Is there something I shold be doing differently?
The script assumes the battery has already been through a charge-discharge cycle.
Li-ion batteries have a non-linear voltage-to-charge curve. Voltage rises quickly in the first 20%, then slowly from 20–80%, and then quickly near 100%.
So a brand-new battery at 4.0 V may actually be almost fully charged, even though the script thinks it’s low.
ahsrab.rifat Thank you for the reply! Does it mean I have first to leave it on until the battery fully discharges?
