RTK Kit accuracy question
userHead Aditya Singh 2025-11-25 11:48:56 948 Views1 Replies
Trying out the RTK kit but the accuracy (Repeatability) seems to be in 10+ metre range. This is static power down and power up testing with base being started each time about 1 min before the rover position is. The setup is on standard tripods so was expecting some noise (2m so there is a sway) but that can only explain minor errors.
Reading 1
Lat: 1.459331 N
Lon: 103.835830 E
Alt: 25 m
Sats: 41
HDOP: 0.5
RTK Float
Reading 2
Lat: 1.459370 N
Lon: 103.835853 E
Alt: 16 m
Sats: 43
HDOP: 0.5
RTK Float
Reading 3
Lat: 1.459384 N
Lon: 103.835845 E
Alt: 17 m
Sats: 42
HDOP: 0.5
RTK Float
Not sure of the reason. Should I buy a different antenna?
Product: https://www.dfrobot.com/product-2970.html
2025-11-27 01:31:09
Put both antennas on solid tripods, keep them stationary, record 10–30 minutes of fixes. Compute mean + standard deviation of lat/lon/height. If the mean drifts by metres between power cycles but is stable during a run, likely initialization or base coordinate problem.
userHeadPic ahsrab.rifat
