Huskylens2 1.1.6 temperature
userHead RoniBandini 2025-11-29 04:01:48 1039 Views2 Replies
I'm working on a project with the Huskylens2. After updating the firmware to 1.1.6, with the WiFi connected and MCP server enabled I noted a significant temperature increase. Is this normal/safe?
2025-11-30 22:18:32
It can be normal that the HUSKYLENS-2 runs noticeably warmer when the Wi-Fi module + MCP server are active, because those features keep the radio and the main CPU/AI pipeline busy. That said, you should check it — it’s usually safe if the temperature stays inside the device’s operating range and the board isn’t getting hot enough to burn fingers or damage nearby parts.
 https://www.dfrobot.com/huskylens/huskylens2?srsltid=AfmBOooP5lJl2Leittwh6ITtNpLnOx723B9VtuhgdliLAgPTVWO3TRsL&
userHeadPic ahsrab.rifat
RoniBandini wrote:
Thanks Ahsrab
2025-12-24 04:23:41
