Millimeter Wave Sensor UART Voltage
Jeffrey.Basso 2025-12-07 14:24:07 1319 Views2 Replies For the SEN0676 80GHz High-Precision Liquid Level Detection Sensor are the UART pins voltage at 3.3 volts are do I need to use a level shifter? Trying to keep parts down in this design and was not sure if there was a simple divider on board.
2026-09-11 16:21:29
Hello.Goodbye
I asked DFRobot by email the exact same question and their answer was:
‘’We have confirmed with our product manager that the UART pins of this millimeter-wave liquid level sensor operate at 3.3V, so no level shifter is required.''
Hope it helps
Hello.Goodbye Jason.Miao
wrote:
2026-09-11 17:29:43 1 Replies
The output voltage may vary between different hardware. This 5V device outputs 3.3V, while others may output 5V. This could cause the circuit board to burn out. Therefore, be careful before using it.
.jpg)
