Compute Module 4 IoT Router Broad Mini endless PXEboot attempts
userHead Joseph.Freivald 2025-12-25 06:04:11 700 Views0 Replies
Hello.
I have a CM4 with Wifi and eMMC with the IoT Router Broad Mini board and case.
I am able to boot the board and access the eMMC via rpiboot.
I copied the OpenWRT image with:
sudo dd if=openwrt-21.02.3-bcm27xx-bcm2711-rpi-4-ext4-factory.img of=/dev/sdb bs=10M
And added
dtoverlay=dwc2,dr_mode=host
To /boot/config.txt
After disconnecting and then re-powering the device, the image is intact with the modifications and can be mounted by my host desktop (running Rocky 9.5) using rpiboot.
The device wasn't coming up so I set up a test network with a separate DHCP server to service the device. In normal boot mode the device will continuously recycle and request a network boot as "PXEClient:Arch:00000:UNDI:002001". This indicates to me that the device is not booting off of the eMMC device, but defaulting to a Network BIOS boot attempt. I also attempted a flashed Pi image on an SD card and it still attempts only booting from the PXEClient.
I hooked a tty serial converter to the device and there is no serial output at any time.
Is there a way to troubleshoot the boot sequence of this board or force it to boot from the eMMC? The dd image should work properly, right?
Thanks.
--Joseph
