Shiftout Module
userHead Account cancelled 2012-07-23 11:27:17 5299 Views2 Replies
  my two shiftout modules have just arrived and I wanted to try them out .
I did a search on this forum and found a post on how to use 2 modules together to shift 16 bits.
The above search result contained ...
#define SCLK 35    // (1) DFR0072 ShiftOut SCLK Serial-Clock Input
#define DIN 31    // (5) DFR0072 ShiftOut DIN Serial-Data Input
#define iCS 33    // (3) DFR0072 ShiftOut /CS Chip-Select Input set low to receive data, set high to output data
I think I understand what the code is doing but am confused by the choice of pin numbers. My arduino doesnt have that many pins so I am guessing he is using the arduino 2560 which has the extra pins.
Will it be ok to use my Uno instead and can I choose more or less any 3 digital pins for the outputs for
SCLK , DIN and iCS
Regards
Don
2012-07-23 18:34:58 Hi DonRecardo,
Did you try searching our wiki. It contains plenty of sample codes and wiring instructions.
https://www.dfrobot.com/wiki/index.php?t ... U:DFR0089)
https://www.dfrobot.com/wiki/index.php?t ... U:DFR0072)
https://www.dfrobot.com/wiki/index.php?t ... U:DFR0090)
These are all using the same shift out module.  The product page also contains sample codes and a link to the wiki.
https://www.dfrobot.com/index.php?route= ... uct_id=189
Happy hacking!
userHeadPic Hector
2012-07-23 14:45:24 Hi,
You can change the numbers if you want. On my uno I usually uses 10, 11 and 12. But it does not change if you use some other pins.
Regards,
The Crusher
userHeadPic The Crusher
