Huskylens / ESP32 / Tag Recognition
Herbert.Gramsch 2026-01-23 23:02:03 919 Views1 Replies Hardware ESP32 DEV Module
Huskylens / Mode ALGORITHM_TAG_RECOGNITION
Arduino IDE 1.8.19
When compiling a sketch, I get an error message in the Arduino IDE and 'exit status 1'.
The critical message in red reads:
/Users/Einhorn/Desktop/Arduino-Daten/libraries/HUSKYLENS/HuskyLensProtocolCore.c: In function 'husky_lens_protocol_write_begin':
/Users/Einhorn/Desktop/Arduino-Daten/libraries/HUSKYLENS/HuskyLensProtocolCore.c:135:12: error: returning 'uint8_t (*)[128]' {aka 'unsigned char (*)[128]'} from a function with incompatible return type 'uint8_t *' {aka 'unsigned char *'} [-Wincompatible-pointer-types]
135 | return &send_buffer;
Can anybody give me an idea where to look for?
Best regards
Einhorndg
Are you using SEN0305 HUSKYLENS or SEN0638 HUSKYLENS 2?
If you are using HUSKYLENS 2, please make sure you have installed the latest firmware image and library files: https://github.com/DFRobot/DFRobot_HuskylensV2/releases
Xiao
