Unihiker K10 Blank Screen and Hums
userHead EB 2026-02-01 20:37:25 599 Views2 Replies
HI, I tried to set up my K10 so that I can program it using Micro Python. Now it has a blank screen and hums. I have tried reflashing it several times with no success. All that happens is that the dot moves across the screen with about 15 lines of dots and never ends. Any suggestions?
2026-02-02 18:12:57
Hi, I was finally able to recover factory settings by first using esptool.py and then restoring device initial settings with Mind+ as shown above. Thanks.
userHeadPic EB
2026-02-02 10:18:39
Hi, sorry about your K10 issue! Could you try restoring its original firmware in Mind+? Is Arduino C programming also abnormal? If possible, send faulty board photos and details to techsupport@dfrobot.com.
userHeadPic Yx
