SEN0322 O2 Sensor readings jump around at 5v
userHead CDVT 2026-02-04 04:50:43 572 Views1 Replies
The sensor is stable at 3.3v from my ESP32 but if I power it at 5.05v from a buck converter, it will report erratic readings bouncing between 19.6 and 21.9. What is the trick to running it at 5V?
2026-02-15 02:18:33
Are you keeping all grounds common? Please check. The buck converter, the ESP32, and the sensor should have a common GND.
userHeadPic love.forcircuits
