The receiver is connected to the controller, why does the receiver receive signal when the transmitter does not transmit?
Yx 2024-07-12 15:04:05 407 Views0 Replies The receiver is connected to the controller, the transmitter does not transmit signal but the receiver receives the signal
2024-07-12 15:04:05 The receiver receives the control of the code, burn the corresponding sample code or burn an empty code to solve the problem
Yx
Yx
