How to use USB for debugging with Serial and SerialUSB on the official Arduino M0 kernel?
userHead Yx 2024-07-12 15:04:05 477 Views0 Replies
2024-07-12 15:04:05 Most of the Arduino examples are debugging and providing output via Serial.print, but the USB port of the official Arduino M0 kernel is changed to SerialUSB.We have fixed this problem so you can use USB for debugging when using Serial and SerialUSB. TX1, RX1 and TX, RX are set to Serial1 and Serial2 respectively. userHeadPic Yx
