Are lever-type terminal blocks prone to damage?
Yx 2024-07-12 15:04:05 434 Views0 Replies Are lever-type terminal blocks prone to damage?
2024-07-12 15:04:05 The service life of lever-type terminal blocks reaches several thousand presses and is not prone to damage. But the wire should not exceed 12AWG. Excessively thick wires may cause the compression spring inside the terminal block to deform or be damaged.
Yx
Yx
