Are lever-type terminal blocks easy to break?
userHead Yx 2024-07-12 15:04:05 440 Views0 Replies
2024-07-12 15:04:05 The service life of lever-type terminal blocks can reach thousands of presses, so they are not easy to damage. However, the wire should not exceed 12AWG. Overly thick wires may cause deformation or damage to the compression reeds inside the terminal blocks. userHeadPic Yx
