Documentation of baudrate for the SEN0592
Gaël.Écorchard 2026-02-06 15:25:58 1053 Views1 Replies The documentation of the baudrate parameter is unfinished: “Serial baud rate (default 115200), in bps, which will take effect immediately after setting. The baud rates corresponding to the register values are as follows: 0x0002: 4800, 0x0003: 9600, 0x0004: 14400, 0x0005: 10.”
Also in the table “Influence of Baud Rate on Single Packet Communication Duration”, the first column “Serial number” doesn't make sense.
The SEN0592 baud rate is configurable via a Modbus register. The default serial baud rate is 115200 bits per second. Original documentation lists incomplete and typoed baud mappings. Register value 0x0002 corresponds to 4800 bps. Register value 0x0003 corresponds to 9600 bps. Additional supported rates include 14400 through 115200 bps. Baud rate changes take effect immediately after writing. Packet duration decreases as baud rate increases. The serial number column is merely a row index. It does not represent any configurable parameter.
love.forcircuits
