Troubleshooting
SEN0492 in sunlight
userHead eva@dailytlj.com 2026-02-07 22:52:01 597 Views2 Replies
I am using SEN0492 sensors (Laser Ranging Distance Sensor RS485) and they are usually working fine, except when they are in a very bright environment full of sunlight. I understand that intense sun (shining onto the sensor surface itself, but also just having lots of reflected sunlight all around) can mess with these kind of sensors.
Do you have any recommendations on how to deal with this problem?
Physical filters?
Any specific sensor settings?
The sensors are configured for the short-distance measurement mode.
2026-02-10 01:22:03
Even indirect sunlight causes problems due to internal reflections. Add a black, matte-finished tube or hood. It must be non-reflective.
userHeadPic love.forcircuits
2026-02-08 22:33:26
The most effective way to handle sunlight is to prevent it from hitting the receiver lens in the first place.
Lens Hood / Long Snout: Attach a small, matte-black "tube" or "shroud" over the sensor. This limits the field of view (FOV) so the sensor only "sees" the target and doesn't pick up off-axis sunlight or reflections from the side.
Infrared (IR) Pass Filters: Since these sensors typically operate at the 940nm wavelength, you can place a 940nm IR-pass filter over the lens. This blocks the visible spectrum of sunlight while allowing the laser pulse through.
Note: Ensure the filter is high quality to avoid diffusing the laser beam.
Recessing the Sensor: If possible, mount the sensor 1–2 inches deep inside your enclosure rather than flush with the surface.
userHeadPic R2D2C3PO
