LattePanda IOTA Freezing On Power Up
T_Ryker 2026-02-08 02:48:02 695 Views1 Replies I just received my LattePanda IOTA and Aluminum Heatsink Case.
I have installed the Aluminum Heatsink Case with the thermal paste.
I am using a USB power supply with capable of 15V and greater than the 1.8A per specs (I have also tried multiple power supplies with no change to the results)
I am using a USB-C cable (I have tried multiple cables with no change to the results)
Upon first boot up I was able to get into Windows and then it had a blue screen of death. It was around 1 minute before it blue screened.
Subsequent reboots end up going into Windows recovery or simply freezing on the LattePanda logo screen.
I got into the BOIS and checked the Hardware Monitor and seeing 25 C for the temp, so that seems ok.
I am able to move around in the BOIS for a few minutes, but it will eventually freeze in there as well.
Do I have a defect unit? What other troubleshooting steps can I perform.
