Unboxing & Initial Experience with Huskylens 2
Philip.Mallon 2026-02-08 11:10:24 891 Views3 Replies I have made a video on this on Youtube. See it at:
Hi, thank you very much for your detailed feedback and the video — it’s extremely helpful for us.
1. We recently released HUSKYLENS 2 firmware v1.2.2 and updated the MakeCode library, which include new features and several bug fixes. Please try updating first and check whether the issue still occurs. If the problem persists, we recommend temporarily removing the middle display expansion board, as it may cause compatibility issues with HUSKYLENS 2.
2. About the Wi-Fi issue you mentioned: could you please describe the exact behavior? For example, is Wi-Fi unavailable or unable to be enabled in “System Settings → WiFi”? Please note that Wi-Fi initializes more slowly than HUSKYLENS 2 itself, so it usually becomes available about 30 seconds after power-on. We would like to confirm whether this explains the behavior you observed.
3. As HUSKYLENS 2 has only been released recently, we are actively improving the software and adding new features. This may require firmware updates during this period, and we sincerely apologize for any inconvenience. Once the software becomes more stable, the latest firmware will be pre-installed at the factory to minimize the need for manual updates.
4. Regarding the system time setting: once Wi-Fi is connected, the device automatically synchronizes the time from the network. That said, your suggestion is very valuable, and we plan to add a manual time-setting option in a future firmware version.
5. For the selfie use case, we suggest trying the “Video Streaming” feature.
6. As for enclosures and mounting brackets, we are currently working on them. Once ready, we will open source the STP files.
Thanks again for your support. Please feel free to continue sharing your feedback and suggestions with us.
JaneYu Hi, thank you very much for your detailed feedback and the video — it’s extremely helpful for us.
2. About the Wi-Fi issue you mentioned: could you please describe the exact behavior? For example, is Wi-Fi unavailable or unable to be enabled in “System Settings → Wi-Fi ”? Please note that Wi-Fi initializes more slowly than HUSKYLENS 2 itself, so it usually becomes available about 30 seconds after power-on. We would like to confirm whether this explains the behavior you observed.
6. As for enclosures and mounting brackets, we are currently working on them. Once ready, we will open-source the STP files.
Xiao Hi, thank you very much for your detailed feedback and the video.
2. About the Wi-Fi issue you mentioned: For example, is Wi-Fi unavailable or unable to be enabled in “System Settings → WiFi”? Please note that Wi-Fi initializes more slowly than HUSKYLENS 2 itself, so it usually becomes available about 30 seconds after power-on.
JaneYu 6. As for enclosures and mounting brackets, we are currently working on them. Once ready, we will open source the STP files.
JaneYu 4. Regarding the system time setting: once Wi-Fi is connected, the device automatically synchronizes the time from the network. That said, your suggestion is very valuable, and we plan to add a manual time-setting option in a future firmware version.
JaneYu 3. As HUSKYLENS 2 has only been released recently, we are actively improving the software and adding new features. This may require firmware updates during this period, and we sincerely apologize for any inconvenience. Once the software becomes more stable, the latest firmware will be pre-installed at the factory to minimize the need for manual updates.
JaneYu For example, is Wi-Fi unavailable or unable to be enabled in “System Settings → WiFi”?
JaneYu 1. We recently released HUSKYLENS 2 firmware v1.2.2 and updated the MakeCode library, which include new features and several bug fixes. Please try updating first and check whether the issue still occurs. If the problem persists, we recommend temporarily removing the middle display expansion board, as it may cause compatibility issues with HUSKYLENS 2.
JaneYu My Youtube channel is: dsrc12
Philip.Mallon Great video, thanks for sharing. It’s helpful to see such a thorough look at the Huskylens 2!
Video link: https://www.youtube.com/watch?v=80Ly1zn5h_M
