dfr0669 with Mega2560 help
Philip.Ellerbrock 2026-02-13 09:19:43 527 Views0 Replies I'm trying to get an image to display on dfr0669 connected to a Mega2560.
My wiring is below:
TFT_CS: 10
TFT_DC: 9
TFT_RS: 8
TFT_SD: 4
TFT_BL: 5
SCK: 52
MISO: 50
MOSI: 51
INT: 2
SCA: 20
SCL: 21
I'm using the example provided in DFRobot_GDL library. I'm defining pins as below:
/* AVR series mainboard */
#else
#define TFT_DC 9
#define TFT_CS 10
#define TFT_RST 8
#define TFT_BL 5
#define TFT_SD 4
#endif
I have uncommented this line:
DFRobot_ILI9488_320x480_HW_SPI screen(/*dc=*/TFT_DC,/*cs=*/TFT_CS,/*rst=*/TFT_RST);
I have updated the filename/path with my image.
Using this sample code with the modifications above, serial monitor outputs “initialization failed”. I have done a few sample sketches via ChatGPT and I have been able to get the SD initialized with this wiring/pinout, but I am unable to get both to work together.
I'm using a Mega2560 as I will eventually need to move pins2, 4, 5, 8, 9, and 10 as I have a motor shield that will be inserted.
