Lattepanda iota sata
CharlesPeak 2026-02-13 00:45:19 683 Views1 Replies Is there a way to get a sata board hooked up to the iota for a raid?
I am finding conflicting information online.
2026-02-13 11:22:27
LattePanda
The LattePanda IOTA does not have a native SATA port or an official expansion board. To set up RAID, you'll need to use adapters:
- Data Connection: Use an M.2-to-SATA adapter (via the M.2 M-Key or E-Key slots) or a USB 3.2 to SATA RAID enclosure.- Power Supply (Critical): The IOTA cannot power SATA drives. You must use an external, independent 12V power source for the hard drives; only the SATA data cables should connect to the IOTA.
LattePanda
