FIT0185 encoder A/B output type and voltage level
userHead Vishal.Pawar 2026-02-19 18:56:19 620 Views0 Replies
Hello DFRobot Support,
I’m using your 12V DC Motor 83rpm w/ Encoder (SKU: FIT0185) with an Arduino Portenta X8 (3.3V logic).
Could you please confirm:
1)Is the encoder output A/B open-collector/open-drain or push-pull ?
2)What is the A/B output voltage level (HIGH level) when powered at 5V?
3)Do A/B require external pull-up resistors? If yes, recommended value (e.g., 4.7k/10k)?
Regards,
Vishal Pawar
