Troubleshooting
Solar Power Manager 5v - When does USB power activate?
userHead James.McGill 2026-02-21 13:54:12 9915 Views4 Replies
I picked up a Solar Power Manager 5v, plugged up the LiPo 3.7v and device to USB-A. Charging power is provided through micro-usb-in. It's been charging a few hours now but the USB-A device has yet to turn on. It works just fine with the same cable plugged into any other power supply, and turns on when I disconnect the battery.
Should the controller not be trickle-charging the battery while also powering the USB port? Is there maybe a charge threshold the LiPo needs to reach before the controller kicks on the USB power? It's a 8000mAh battery, so that just might take a long time.
Thanks for any help!
2026-07-26 13:10:20
Yes, most solar charge controllers/power managers do have a minimum battery voltage threshold before they'll enable the USB output — this is intentional, so the controller prioritizes getting the battery to a safe charge level before drawing additional current for USB output, which would slow down charging or even cause the battery to never reach a safe voltage in low-sun conditions.
Check the datasheet or product page for this specific Solar Power Manager 5V board — it should list the exact voltage threshold (often somewhere around 3.4-3.5V for LiPo). If your battery was deeply discharged, it can take a while to climb past that threshold, especially with only a partial charging current. Try measuring the battery voltage directly with a multimeter to see where it currently sits relative to that threshold.
userHeadPic Nazar.Electronics
2026-04-01 10:17:53
To protect the lipo battery, the USB OUT output will not be activated immediately when the Solar Power Manager is replaced or powered on. You need to press the BOOT button on the board to enable USB OUT output.
userHeadPic Yeez_B
2026-03-30 10:31:00
Hi, if the battery voltage drops below 2.4V, the output is cut off to prevent over-discharge.
Additional protection notes for reference:
1. Charging stops when battery voltage exceeds 4.3V (discharge still works)
2. Discharge path shuts off if discharge current exceeds 3A
userHeadPic Yx
2026-03-29 15:31:59
This behavior is actually normal for many Solar Power Manager 5V boards. They often don’t support true pass-through (charge + output at the same time), so the USB-A port may stay off while the battery is charging.
Some boards also require the LiPo to reach a minimum voltage threshold before enabling output, especially if it was deeply discharged.
If it powers your device when the battery is unplugged, that suggests the module prioritizes input power differently—check the datasheet, but most likely it’s a design limitation, not a fault.
userHeadPic parker.king
