5V Metal Proximity Switch: What is the detection area?
userHead Gladys.Birchfield 2026-03-04 11:55:48 587 Views2 Replies
Could someone please confirm whether the detection zone is exactly the crosshair marked on the device? In other words, will the device detect a metal object positioned within 4 mm of that crosshair?
I assume that is what the marking in
2026-03-05 12:40:46
I’m not completely sure about the exact detection point, but based on similar devices I’ve used, the detection zone is usually centered right around the crosshair marking. If that’s the case, a metal object placed within about 4 mm of that point should normally be detected, though it may still depend on the sensitivity settings and the material type.
userHeadPic Susan.Hopkins
2026-03-05 10:24:37
Hi, the crosshair marked on the 5V Metal Proximity Switch is exactly the position of the induction coil. The switch will be triggered when a metal object is within 4 mm near this crosshair area.
userHeadPic Yx
