Question About the Exact Detection Zone on the Sensor
Susan.Hopkins 2026-03-05 12:42:50 804 Views1 Replies Hello everyone,
I’m currently working on a small project using one of the sensors from DFRobot, and I would like to clarify something about the detection zone marked on the device.
On the top surface of the sensor, there is a crosshair marking, which seems to indicate the center point of detection. I would like to confirm whether this crosshair is exactly the active sensing point of the device. In other words, if a metal object is positioned very close to that mark — for example within about 4 mm — will the sensor reliably detect it?
My assumption is that the crosshair indicates the center of the detection field, but I am not sure whether the detection area is strictly limited to that point or if it spreads slightly around it.
Understanding this detail would help me position the sensor more accurately in my setup, especially since my design requires precise alignment between the sensor and the metal target.
If anyone has tested the exact detection range or has experience with the alignment of this sensor, I would really appreciate your insights.
Thanks in advance for your help!
Hi!
1. The crosshair marking is the center of the detection field and serves as the reference for precise alignment.
2. Metal targets within 4 mm of the crosshair can be reliably detected. The detection field spreads slightly around the center, with the highest sensitivity at the crosshair.
3. For optimal precision, you may align your target with the crosshair center during installation.
Please share the sensor model/SKU if you need more accurate specifications.
Hope your project goes well!
Yx
