How to know when sen0658 is "ready"
johnterickson 2026-03-09 06:48:50 805 Views2 Replies Is there an official way to determine when sen0658 is ready and reporting correct values? I am able to interact with the sensor over the RS485 and checksums are fine, but initially many of the values are 0 until I retry multiple times, but the wind speed sensor also returns all zeroes accurately when there is no wind. Is there a way to determine the sensor is ready? e.g. it will always be ready after 10 seconds? Or sensor X is the slowest to start up and once it returns non-zero values, then it's safe to read all values?
Thanks!
You could try adding a short stabilization delay after powering the sensor. In many cases, weather sensors need a few seconds to initialize before they start returning reliable data. Waiting around 5–10 seconds before the first read can sometimes solve the issue.
Another practical approach is to read the values several times and discard the first few responses. If the checksums are correct but the values are still zero, it may simply mean the sensor has not finished initializing yet. Once you start receiving consistent readings across multiple queries, it is usually safe to assume the sensor is ready.
Since the wind speed sensor can legitimately return zero when there is no wind, it may be better to check other parameters such as temperature or humidity to confirm that the sensor has started reporting real data. If those values appear reasonable and stable, the system is likely fully initialized.
Marvin.Wyatt Hi, the SEN0658 Wiki notes PM2.5/PM10 have the longest response time (≤90s) of all sensors. Use them as the readiness indicator: add a 90s wait after power-on, monitor PM values, and start polling all data once they stabilize.
Yx
