Question About Programmatic Hot-Swap Control for DFR1168 USB4 to PCIe Dock
Marvin.Wyatt 2026-03-09 18:25:12 761 Views2 Replies Hello everyone,
I am currently integrating the DFR1168 USB4 to PCIe docking station into a custom product and I am trying to control the hot-swap function from my own control board. After reading the available documentation, I am still a bit unsure about the correct setup for SW1 and SW2 when using forced startup mode.
My main question is about triggering a hot-swap event to the host system. Would temporarily disabling J3/J4 and then enabling them again be the correct way to simulate this behavior? If so, is there a recommended delay time that J3/J4 should remain disabled before turning them back on?
I am also wondering whether the board provides any dedicated header or signal that allows external control for this function. If not, is the only practical solution to remove J3/J4 and connect them to a custom control circuit on my PCB?
Any suggestions or experience with this setup would be very helpful. Thanks in advance!
Hi, toggling J3/J4 off and on will be recognized as a valid hot-swap event. We recommend a delay of around 5 seconds.
There is no dedicated external control header. You will need to run wires from the J3/J4 switch pads or remove the switches and control them via an external relay.
Yx
