LattePanda 18650 UPS Expansion Board
pkixcc 2026-03-11 03:25:43 732 Views2 Replies do i need to switch the dip's or power the ups from usb or DC to use that 11V? i have 3 charged batteries but voltage meter connected to gnd and vbat shows 0V:(
2026-03-11 19:32:39
pkixcc
thx. i just tested it and when USB-C is connected there is output on serial but after i disconnect power input serial stops too:( i wanted to simply discharge the batteries using that output without any power input. Any other options?
pkixcc 2026-03-11 11:30:49
Yx
After installing the batteries for the first time, you need to power the expansion board via DC or Type‑C to activate it. Then it will work normally.
This has nothing to do with the DIP switches.
You can find details in the wiki. https://wiki.dfrobot.com/dfr1247/docs/19075
Yx
