unihiker k10 password reset
ROBERT.YUSKO 2026-03-17 07:44:07 781 Views2 Replies The k10 comes on, but when I try to connect thru Mind+ it comes up with a username (root) and password (dfrobot) which does not work. How do I reset the password for the Unihiker k10?
Thanks for the help. Your links helped allot in getting the K10 working.
ROBERT.YUSKO Hi there!
Please double-check your board model first.
The Unihiker K10 does not require a username and password for connection.
For the M10, when connecting via SSH, the username (root) and password (dfrobot) are filled in automatically by default — you don’t need to change them.
Connection failures are usually caused by other issues. You can refer to this link for M10 troubleshooting: https://www.unihiker.com/wiki/Troubleshooting/The_UNIHIKER_cannot_be_connected_to_Mind/
Wiki link for K10: https://www.unihiker.com/wiki/K10/GettingStarted/gettingstarted_mindplus/
Wiki link for M10: https://www.unihiker.com/wiki/GettingStarted/gettingstarted_mindplus/#run-a-simple-example-with-python-code/
Yx
