Is manual calibration required prior to deployment?
userHead Cyn 2026-04-10 10:36:41 418 Views1 Replies
2026-04-10 10:36:58
No. The hardware is rigorously factory-calibrated for immediate use. For lifecycle maintenance after prolonged submersion, the sensor supports electronic recalibration via register commands utilizing the included 12880μS/cm standard solution.
userHeadPic Cyn
