USB Port Power Control on IOTA or 3 Delta
David.Pearson 2026-04-15 02:55:34 466 Views1 Replies I need to disable power delivery to the USB ports on either the IOTA or 3 Delta (I don't have hardware yet), under software control. I plan on running Ubuntu Linux 22.04, and to use a utility such as uhubctl to do the power control.
I see the BIOS settings (as described in the BIOS Documentation) will allow me to control what happens when the board is powered-off (Hibernate and Shutdown modes). But my need is for an application to turn the USB port power off (VBUS = 0V) while the system is in Running mode.
Does anyone know if this is possible?
