DFRobot MOSFET Power Controller DFR0457 - freewheeling diode
userHead Mario.Kazana 2026-05-27 23:34:35 1470 Views1 Replies
I have a DFRobot DFR0457 MOSFET module where there is this information:
The Gravity: MOSFET Power Control Module is a versatile component that allows low-current microcontroller units (MCUs) such as Raspberry Pi and Intel Edison to control high-current devices. It operates with a wide voltage range of 5~36V VIN and can handle up to 20A of current. The module is equipped with a PH2.0-3P Gravity interface, making it compatible with various Arduino IO shields for a plug-and-play experience. Ideal for robotics and other applications requiring fast switching up to 1KHz, it is crucial for projects involving inductive loads like motors and solenoids to use a freewheeling diode to prevent back EMF damage. This module is a critical component for anyone looking to expand the capabilities of their MCU projects.
How do I properly add a freewheeling diode to switch inductive loads (motors, electromagnets, relays)?
Where and how should I correctly insert a protective diode to protect the module, and what is the best diode for this purpose?
2026-06-01 14:33:04
Hi, add the freewheeling diode directly across the inductive load.
For DFR0457, the load should be connected between VOUT and GND. Connect the diode in parallel with the load: the cathode/striped end goes to VOUT, and the anode goes to GND.
During normal operation the diode is reverse-biased. When the MOSFET turns off, the coil current can recirculate through the diode instead of creating a high back-EMF spike.
For diode selection, choose a reverse-voltage rating higher than your supply voltage and a current/surge rating suitable for the load. A 1N400x is usually fine for small relays or solenoids. For PWM, motors, or faster switching, use a Schottky or fast-recovery diode with enough current margin.
userHeadPic Yx
