Home Assistant Tutorial for SEN0691 Causes ESP32 Device to Crash
John.Nowakowski 2026-06-09 01:01:44 775 Views2 Replies I'm following the tutorial for integrating the SEN0691 mmWave sensor in Home Assistant. When I put in the configuration from the tutorial, any ESP32 that I use crashes. I'm using version 2026.5.3 of ESPHome and the only sensor connected is the SEN0691. The backtrace is included.
[13:51:24.510]Backtrace: 0x4008347f:0x3ffb9ae0 0x40116fe1:0x3ffb9b00 0x40118323:0x3ffb9b20
WARNING Found stack trace! Trying to decode it
WARNING Decoded 0x4008347f: xt_utils_wait_for_intr at /COMPONENT_XTENSA_DIR/include/xt_utils.h:82
(inlined by) esp_cpu_wait_for_intr at /COMPONENT_ESP_HW_SUPPORT_DIR/cpu.c:55
WARNING Decoded 0x40116fe1: esp_vApplicationIdleHook at /COMPONENT_ESP_SYSTEM_DIR/freertos_hooks.c:58
WARNING Decoded 0x40118323: prvIdleTask at /COMPONENT_FREERTOS_DIR/FreeRTOS-Kernel/tasks.c:4350 (discriminator 1)
Turns out I had a bad connection. Everything is working correctly now.
John.Nowakowski
