Overlord Support/Parts
William.Tocci 2026-06-26 03:37:01 644 Views1 Replies I bought a used Dream Maker Overlord. It is in pretty rough shape. I need a power supply but haven't been able to find a proper unit with 12v on pins 1 & 2.
Also, I don't see any feed tubes on my machine. Are there any or they not necessary?
any help would be appreciated!
2026-07-31 09:16:44
Hinar.Joestar
Hi, the OverLord does not use a 12V power supply.
The standard OverLord requires 24V/5A, while the OverLord Pro requires 24V/9.2A. Please do not connect a replacement power supply until the connector polarity and pinout have been confirmed, as an incorrect connection may damage the mainboard.
There should also be a filament feeding tube between the extruder and the hotend. If it is missing, it will need to be replaced before printing.
Hinar.Joestar
