Why is the DO reading lower than expected in freshwater?
userHead Yx 2026-07-23 11:40:57 405 Views1 Replies
2026-07-23 11:42:36
SEN0681 defaults to a salinity setting of 30‰ for seawater applications. When used in freshwater, set the salinity value to approximately 0‰ or the actual salinity of the water.
If the DO reading is unusually low, check whether the salinity setting matches the test environment.
userHeadPic Yx
