General Raspberry Pi
Regarding the vibration resistance of the SEN0630
userHead Shotaro.Fudo 2026-07-28 10:32:11 425 Views3 Replies
Does this camera module (SEN0630) or image sensor (IMX219) have image stabilization function?
The image remains steady even when cause a high-frequency vibration.
2026-07-29 13:33:36
yeah it's got software stabilization, that's why it stays steady. The IMX219 doesn't have hardware OIS, so libcamera's doing the digital compensation.
If you're gonna use it on something with constant vibration, rubber mounting pads help a lot. But for normal use it handles it pretty well.
userHeadPic Jason.Miao
Shotaro.Fudo wrote:
Thank you for your reply.
Do you mean that the camera module (SEN0630 & IMX219) does not have this function?
So, it's highly likely that vibration compensation is being handled by the connected software, such as the Raspberry Pi?
2026-08-02 14:02:12
Jason.Miao wrote:
the module itself has zero stabilization built in, you're right. No hardware OIS, no onboard digital processing. The steady image comes from the host software, like libcamera's EIS on Raspberry Pi. So yeah, the Pi is doing the compensation, the module just feeds raw frames.
2026-08-03 09:52:39
