Sending downlink data to Agrosense node to change reporting interval
Dave.Barker 2026-07-28 23:14:36 267 Views1 Replies Another newbie question. I want to use the admin console on the DFrobot lorawan gateway to send a downlink to an Agrosense node changing the reporting interval. According to the Agrosense docs, the payload should be in hex. I want to change the interval to 5 minutes (but ultimately to something longer).
This is what my screen looks like. I don't see any obvious error, but it doesn't appear to do anything. I'm resetting the node to get it to connect so it can check for available downloads.
Any help appreciated, thank you
2026-07-29 02:54:01
Dave.Barker
Resolved: I was using the wrong port - should be 1 (although I really thought I tried several values)
Dave.Barker
