ETA on firmware update for DFRobot indoor lorawan gateway DFR1093-915?
Dave.Barker 2026-08-17 06:22:44 341 Views2 Replies Let me preface this by saying I really like the utility of this gateway, in particular the built-in lorawan server and node red application. However, it suffers from frequent hangups and restarts. Is there a location where one can track the status of firmware updates to this device?
Dave Barker
Thanks for the info. FWIW, I'm powering the unit with the supplied proprietary adapter; it's not USB.
Dave.Barker There's no public firmware tracker for the DFR1093 that I could find — the Wiki mentions future updates but doesn't list a changelog or roadmap.
On the hangups: the DFR1093 specs call for a power source above 20W / 2A. If you're running it off a weak USB port or underpowered adapter, the SX1302 concentrator plus the Cortex-A35 running Node-RED can brown out and restart. Try a beefier supply first before blaming firmware — the gateway pulls more than most indoor IoT hubs.
Jason.Miao
