Troubleshooting
How to calculate or display CH₄ concentration using DFRobot SEN0565 with ESP32
userHead Nandhini.Manikandan 2026-08-17 18:20:31 306 Views3 Replies
Hello DFRobot team,
I am using the **Fermion: MEMS Methane CH4 Gas Detection Sensor (Breakout, 1-10000ppm) | DFRobot Wiki**.
I have some doubts. My questions are:
1. Does SEN0565 provide an official voltage-to-CH₄ ppm conversion formula?
2. Is there a recommended clean-air baseline voltage or baseline resistance?
3. How should the sensor’s analog output be calibrated?
4. Can the listed detection range be converted into a reliable ppm value?
5. Should I display the result as ppm, relative gas level, or only gas presence/status?
6. Is there an official warm-up or stabilization time before calculating the baseline?
7. Does the analog output increase or decrease when methane concentration increases?
8. Is there an official sample code for this CH₄ sensor with ESP32?
9. Can you recommend a factory-calibrated DFRobot sensor for actual CH₄ ppm measurement?
Thank you.
Regards,
Nandhini M
2026-08-18 11:32:17
Warm-up is >5 min on first power-up, or >24 h if it has been sitting unused.
actual ppm/%LEL numbers, the factory-calibrated version is the SEN0654. It outputs concentration over UART at 115200 and has an Arduino library.
在官方回答你问题前,你可以看看wiki有没有你的答案先
https://wiki.dfrobot.com/sen0565/
https://wiki.dfrobot.com/sen0565/docs/18020
https://wiki.dfrobot.com/sen0654/docs/20697
userHeadPic Jason.Miao
Nandhini.Manikandan wrote:
Hello DFRobot team,
Thank you for your clarification and documentation links.
I understand that SEN0565 provides a qualitative analog response and that SEN0654 is the factory-calibrated alternative. I would like to clarify the following points:
1. What is the practical purpose of printing the raw analog value in the SEN0565 Arduino example code part?
2. Does the SEN0565 analog output normally increase or decrease when CH₄ concentration increases?
3. Is there any recommended method for calculating a clean-air baseline using the raw ADC value, voltage, R0​, or Rs?
4. Is the listed 1–10,000 ppm range only a detection range, or can it be used for approximate concentration estimation for CH4?
5. Does DFRobot provide any typical response curve or sample raw values at known CH₄ concentrations?
My intended application is to display the current methane status on an LCD. I would like to know whether to display: CH4 ppm or Relative gas level (%CH4 in air) or Gas detected status (normal, warning)
2026-08-18 15:15:38
Jason.Miao wrote:
You need to ask the df technical support team. I'm just an enthusiast.
2026-08-18 15:22:00
