DFplayer mini 'pop' noise
Richard.Hutchinson 2026-08-20 02:06:33 310 Views4 Replies Hi, I'm getting a loud ‘pop’ after I play an mp3 file
I can play several sounds together with no ‘pop’ in between them, it just does it right at the end when the last file has finished playing.
Any ideas ?
I tried the capacitor, no change at all.
Tried other things too, inc larger PSU.
Is there a way to stop the amp turning off and on (i.e. have amp on all the time) ?
Richard.Hutchinson Haven't used this one myself, but a few fixes turned up:
The auto-mute solder bridge on the back of some boards kills the pop — move it so the mute pin stays high until playback starts. Or pull the 0Ω resistor off the 8002 mute pin and wire it to a GPIO for software control.
https://wolles-elektronikkiste.de/en/arduino-controlled-dfplayer-mini
https://done.land/components/audio/playback/dfplayermini/
Saw this FAQ a while back
https://zbotic.in/arduino-mp3-player-dfplayer-mini-music-box-build/
If you find a cleaner fix drop it here.
Jason.Miao
.jpg)
