Unihiker M10 and DFR1154 issue - M10 cannot see it
userHead Chris.Stewart368 2026-08-27 23:46:58 279 Views2 Replies
I am trying to pair the M10 with the DFR1154 using a usb c to usb a cable. The M10 cannot see the DFR1154.
I keep getting error -62.
I look online and internet says:
"The ESP32‑S3 USB peripheral is known to:
enumerate successfully
then crash
then reset
then disappear
then sometimes reappear
then sometimes fail with error -62
then sometimes do nothing at all"
Is this your experience? Is there a workaround? Or do I need to look for another cam/mic/speaker solution?
thanks for your time,
Chris
2026-08-28 09:06:10
The DFR1154 Type-C is for power and code upload. The USBWebCamera on the wiki is an example you need to flash — it's not a UVC webcam out of the box.
userHeadPic Jason.Miao
Jason.Miao wrote:
You can choose to purchase a plug-and-play camera, which eliminates the need to burn the firmware.
2026-08-28 09:13:40
