Maqueen replacement motors
Davide.Gomba 2026-09-12 18:09:49 331 Views1 Replies Hi!
I'm a proud owner of several Maqueen Plus.
One of the motors is not working anymore!
How to replace it? Is DFRobot selling it?
2026-09-15 11:52:12
Jason.Miao
Yes — DFRobot sells the replacement motor as SKU DFR1225. It's $7 and comes with the motor, bracket, screws, and cable. The motor has the Hall encoder pre-installed, so it's plug-and-play.
Swap steps: power off, pull the wheels, unplug the motor cable, unscrew the 4 bottom screws. Reverse to install. Align the flat on the motor shaft with the wheel groove when you put the wheels back on.
https://www.dfrobot.com/product-2954.html https://wiki.dfrobot.com/dfr1225/docs/24639
Jason.Miao
