FIT1034 connectors
Ian.Steel 2026-09-27 00:21:34 250 Views1 Replies What exactly are the connector types on this motor and sensor board? the documentation does not show anything
2026-09-28 09:12:16
Jason.Miao
From the wiring diagram: this board connects two ways.
The encoder/sensor side is I2C - 4 wires (5V, GND, SCL, SDA) running to the shield's I2C port; the sensor connector itself is GH1.25-4Pin (from the spec table).The motor side is the three-phase UVW leads (3 wires) that go into the motor driver. So it's one I2C link for feedback + the UVW phases to the driver. Spec: https://wiki.dfrobot.com/fit1034/
Jason.Miao
