Arduino R3 Plus DFPlayer Pro = Barely Any Sound Volume
MIchaelAnderson 2026-10-09 07:51:00 543 Views6 Replies I am using a DFPlayer Pro sound module driven by an Arduino Uno R3 to play sounds for a Halloween project and I can get only a very faint sound (barely audible) from powered speakers.
I’ve tested with three different sound modules (all DFPlayer Pro originals from DF Robot, no clones).
I have used three different sets of powered speakers, which are plugged into the DAC connectors on the sound module. Same result for all three: very low volume.
Tried both ground connections coming off the Uno. No improvement.
Tried a different Arduino Uno R3 board.
I can hear the music playing very faintly so I know the various .wav files are correct. Checked the sound files sample rates (1441). Tried the same sound files as mp3’s.
When I plug in a small unpowered speaker to the speaker outputs on the module (R+ and L+), I get the same thing: very faint sound.
I understand that the default volume setting on the module is 20 out of 30. I’ve tried unplugging power to everything (to reset them) but no improvement.
This is interesting: I have powered the setup two different ways: desktop USB to the Uno and then to the sound module; and powering the sound module externally with a 5 volt wall wart. I am carefully connecting all grounds. Using this external power arrangement (which I need to do in the final version), I get no sound at all.
By the way, I am not using any serial code or connections. I’m triggering play by simulating a button push using the following code (which seems to work fine):
pinMode(7,INPUT);
delay(100);
pinMode(7,OUTPUT);
digitalWrite(7,LOW);
I am at a complete loss. Can anyone suggest why I can’t get this to play at a normal volume?
Thank you for the advice. I'm going to need more help and I don't see any way to send you a private message on this forum. Can you please contact me at mra_brimstone@earthlink.net? I will pay for your time if you can help.
MIchaelAnderson Have you tried using the official examples? So, is the result still not satisfactory? https://wiki.dfrobot.com/dfr0768/
You should directly contact the technical support. They will reply to you at techsupport@dfrobot.com.
Thanks. I downloaded the sound robot library but I don't have any idea how to use it. At this point, I think all I need is to initiate the remaining modules so that I can get the output/volume I need. Where can I get an “explain it like I'm five” sort of description for this?
BTW, this is a one and done deal for me so I'm not bothered by not learning any more than necessary to get it finished. I'd really like to take this away from this forum to email if you wouldn't mind.
Hello, could you please try out your method and see if it works? Regarding the DFPlayer Pro module, I usually refer to the wiki and troubleshooting methods on the dfrobot official website. If you are looking for more beginner-friendly tutorials, you can directly ask the AI about this module or search for other unofficial tutorials. Then, choose the one that suits you best.
Burn a small example program using the official library of DFRobot DFPlayer Pro
Jason.Miao Three modules, three speaker sets, and DAC + speaker outputs all faint at the same time - that's a systematic cause, not hardware luck, and it almost never is the .wav either.
The DFPlayer Pro volume has two independent stages: the system volume (your 20/30) AND the on-board codec/DAC gain. Triggering it with a simulated button press means you never ran the official boot initialization, so the codec gain register sits at its low factory default. That "faint but audible" sound is exactly what that looks like - the second stage is never being turned up.
Quick isolation test: don't trigger by button - flash a small Arduino sketch using DFRobot's DFPlayer Pro library, call the example that sets the codec gain/DAC gain to a decent level, and play track 1. If that suddenly plays at normal volume, it was the unanswered codec gain all along, and you can keep button-triggering afterward for your final setup (just initialize the library/gain first).
On the external-PSU case: powering the module from a 5 V wall wart should work, but the on-board amp draws peak current, so make sure the wart is big enough and that its ground is genuinely shared with the Uno. If it goes to zero audio only on external power, that's a supply/grounding symptom, separate from the faint-volume one, so fix the gain issue first, then re-test the wart.
